06-25-2014 08:53 PM
I am going through the NI DAQ Software Suite 4.5 to set-up the DAQ on my computer. The prompt is telling me to "Enter all serial numbers for the products in this installer that you want to install." I have tried entering several different serial numbers I've found on the DAQ and on the box, but none of the numbers are valid. What do I do?
06-25-2014 10:11 PM
06-27-2014 02:46 PM
I attached a screenshot of the prompt, so maybe that will help.
06-27-2014 04:16 PM
06-27-2014 06:48 PM
I don't remember having to put in a serial number when I did the myDAQ back in February. Try just leaving it blank and see what happens.
07-02-2014 09:16 AM
I am trying to install NI-DAQmx 9.7.5 and am getting an "unknown error".
07-07-2014 09:34 AM
Greetings anthonytony
Have you tried installing the latest version of the NI DAQmx driver? You can download it from this link.
http://www.ni.com/download/ni-daqmx-9.9/4707/en/
If it doesn’t work, I would recommend you verify that no remnants of the last installation remain and also cleaning the Windows registry. Let us know if your problem persists.
Warm Regards,
