11-18-2014 02:11 PM
We are looking to update a manual test box.
We are looking for a DAQ product with analog outputs capable of +/- 12V
We are not generating waveforms. Just using LabVIEW to set a voltage and adjust it in the range of -12V and +12V.
Does NI sell anything with this capability?
I have found the NI PCI-6703 and would serve our needs except that it is +/-10V.
11-18-2014 03:58 PM
It would probably be less expensive to add an opamp with gain of 1.2 running from +/-15 V power supplies.
Lynn
11-18-2014 07:39 PM
11-18-2014 09:17 PM
Lynn
True. We will have to seriously consider doing that since I know cost will be a big factor in the ultimate decision made by management.
