When an external timebase changed by using the RTSI bus as described in http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/5601c8268d625a3c86256cf50071199d?OpenDocument, this will change the DAQ cards Master Timebase. The MasterTimebase signal, or Onboard Clock, is the timebase from which all other internally generated clocks and timebases on the board are derived. Therefore, both the scan and channel rate be based on the external timebase.
