09-18-2015 06:51 PM
I am using a USB 6009 DAQ device and am trying to continuously acquire samples from 4 analog input channels. I am getting a strange intermittant error:
Error Code: -200284
NIDAQ Data Acquisition RevD.vi<append>
<B>Property: </B>RelativeTo
<B>Corresponding Value: </B>Current Read Position
<B>Property: </B>Offset
<B>Corresponding Value: </B>0
<B>Task Name: </B>Data Acquisition
I am using a simple VI in Labview consisting of a slightly modified continuously sampling DAQ assistant inside of a while loop.
The error will only occur sometimes when the VI is started and once it starts without error it will continue to run without any issues.
09-21-2015 11:45 AM
Hi littleowl960,
