Can I run the acquire and generate DAQ Assistant Express Vi's at the same time in one LABView program? I am using LABView 2010. It is acquiring and generating waveforms to a NI USB-6009.
You can acquire and generate in the same VI but obviously you cannot generate a waveform unless you do it a single point at a time inside a loop with On Demand sampling and can live with the low samples/sec spec.
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
