12-12-2015 04:10 PM
Hello everyone
I'm trying to generate an analog output with a DAQ USB-6008, generating some unusually waveform using a matlab script but i get some troubles, (i'm also reading the signal with an Analog input of the same DAQ) i can't write the waveform to the output of the DAQ. First I try using a "simulate signal VI" and everyting was right, but when a tried to write the values of 1D array generated in the script it doesn't work. I'm learnig Labview since yesterday and i realy need some help 😕 Thanks
12-12-2015 04:44 PM
