Multifunction DAQ
DAQ 6353 on linux
I'm new to National Instruments products. We have a NI PCIe-6353 X Series Data Acquisition board, and would be of our interest to use it under linux.
Is it possible, or they are incompatible?
Best regards.
(3,968 Views)
Hi!!!
You are using a X Series board, which uses the DAQmx driver.
On the links below you'll find helpful information:
Technical Assistance for Linux and National Instruments Products
http://www.ni.com/white-paper/11803/en#1
NI-DAQmx and NI-DAQ Driver Support: Main Page
http://www.ni.com/white-paper/6909/en
NI-DAQmx for Linux Frequently Asked Questions
http://www.ni.com/white-paper/3695/en#toc2
NI-DAQmx and NI-DAQ Driver Support: PCI/PXI Devices
http://www.ni.com/white-paper/6910/en#xseries
Programming Data Acquisition for Linux with NI-DAQmx Base
http://www.ni.com/white-paper/3838/en
NI-DAQmx for Linux®
http://sine.ni.com/nips/cds/view/p/lang/en/nid/202381
Barbara Pracek
Engenharia de Aplicações
National Instruments Brasil
(3,949 Views)
Thank you very much Barbara, I wonder how I missed those pages.
Best regards.
(3,944 Views)
Hello again, I've another question, about this board.
Is it possible to install one board PCIe 6353, and another equal (or very similar) on the same computer?
I need 8 analog outputs (the 6353 has only 4), so with another board, of 4 analog output, I can solve my problem, if they work together without problem in the same motherboard...is it possible to do?
Best regards!
(3,857 Views)
Hey!
That's no problem you can use two equal boards on the same PC. Smiley Wink
They are indentified by the serial number, therefore there is no possibility to any type of conflict.
Barbara Pracek
(3,847 Views)
http://www.ni.com/white-paper/6910/en/
According to that page, the 6353 is not supported on Linux, unfortunately.
(3,573 Views)
