NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
PRANAV420
Cross talk between two DAQs
[ Edited ]
Hello Guys,I have a problem if you can help me, it will be much appreciated!!!!
 I am using two different DAQ devices on two different
computers. I am using BNC 2111 (PCI 6221) on one system and USB 6008 on
another. I have connected these two device with T-junction BNC, which means
that the incoming signal (signals are analog from 0 to 10 VDC with BNC
wires) are divided into two at BNC 2111; one goes into BNC2111 and other goes into
USB 6008. I think I am having a cross talk between these two acquisition
devices; when USB 6008 acquire the data I see a little peak in data at BNC 2111. So
to solve this problem I was think to use BNC ground loop isolator available in
the market for video surveillance (these are available from DC to MHz range:
http://www.smarthome.com/70431/Enforcer-In-Line-BNC-Ground-Loop-Isolator-VG-1C12AQ/p.aspx ).
Can you please suggest of what do you think about the problem and solution?
And feel free to suggest any other solution or any other device-type. I will
really appreciate it.
Thankyou and thanks for reading this:smileyhappy:
Member
C-Dav
Re: Cross talk between two DAQs
Take a look a this document regarding reducing cross talk in BNC connector blocks, it gives some good suggestions for reducing the effects you're seeing.
Chris D.
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
