04-06-2014 04:10 PM
What should I consider when deciding whether to define an NI-DAQ Task in the code or in MAX for a production application?
04-07-2014 01:53 PM
StevenATK,
The main difference between creating a task in NI MAX vs LabVIEW is in how you edit or create the task. Whether or not you create the task in NI MAX or in LabVIEW, the task is a part of the DAQmx API so the two aren't fundamentally different.
The following link dicusses creating a virtual channel and using it in both NI MAX and LabVIEW
04-07-2014 01:53 PM
04-07-2014 03:37 PM
