10-06-2014 05:39 AM
10-07-2014 03:33 AM
Dear Beck777,
Depending on what are you connecting on the other side of the cable, we can provide different options for connecting.
If you can provide me with information about the device you are connecting, on the other side, to your USB-6351, I will be able to provide you with better option(s).
Kind Regards,
Bozhidar
10-07-2014 05:47 AM
10-07-2014 06:36 AM
Dear Beck777,
Unfortunately only DAQ devices with mass termination support controlling SCXI-1000, even if you try to connect it, is not configurable in MAX.
To be able to use your chassis you will either need another DAQ device with mass termination connection (ex. NI USB-6361), or you could use NI SCXI-1600, which is a separate DAQ device that plugs in one of the slots in the SCXI chassis and controls it.
Kind Regards,
Bozhidar
10-07-2014 06:36 AM
Dear Beck777,
Kind Regards,
Bozhidar
