08-11-2015 08:50 AM
I want to connect a cDAQ-9178 chassis to a cRIO-9081USB port.
The cRIO-9081 has Windows Embedded 7 on it. I have written a LabVIEW FPGA program that gets loaded into the cRIO's FPGA. Once the FPGA is started, the FPGA basically ignores the Windows side, very minimum data exchange.
I want to use the WIndows side to run a cDAQ program. I have to do it this way because the cRIO has 7 modules in it and the cDAQ has 7 modules.
Whenever I insert the NI-DAQmx 14.5 CD into a CD drive on the cRIO, I only see the cRIO drivers. How do I get the cDAQ drivers installed?
08-11-2015 04:51 PM
