01-03-2017 02:51 PM
I have a pressure transmitter that I would like to read with PCI 6289 DAQ. I assume I have to connect the transmitter's signal line to one of the channels but I am a little confused because I can't find the data sheet for AIchannel and Gnd combination.
And how do I map that to the Analog Input on the DAQ? For example, I have thermocouples connected to SC modules where I know which channels I connected and I can create a DAQmx task with the channels to read.
The pressure transmitter has 2 power lines, a signal line and a cable screen line
01-05-2017 07:59 AM
Here you can find the data sheet of PCI-6289, where on p.19 the pinout is illustrated:
PCI-6289 Data Sheet
http://www.ni.com/datasheet/pdf/en/ds-25
