11-24-2014 05:03 PM
I have an Omega PX309-10KG5V Pressure transducer that operates between 0-5V and requires a 9V excitation (http://www.omega.com/Pressure/pdf/PX309-5V.pdf).
I am having trouble getting the transducer running on my SCXI box with a SCXI 1520 card. I think I should be using custom voltage with excitation. I am not sure what I am missing.
Any help is appreciated.
Thanks!
11-25-2014 02:13 PM
floydie83,
How are you trying to create a task, through MAX? LabVIEW? SignalExpress?
What problems are you running into specifically?
11-26-2014 02:31 PM
12-01-2014 04:41 PM
Are you able to run the task in MAX or do you get an error? What kind of data are you receiving? Can screenshot it and share it?
12-02-2014 07:30 AM
will do this afternoon! Thanks.
12-02-2014 05:58 PM
Okay, I hope I have the wiring correct. I am attaching two pictures that show the wiring to the SCXI 1314 and the settings I am using in MAX.
The transduce requires 9-28 V of excitiation. The gage just reads 0V or 5V depending of the direction of the wires. Am I missing a jumper?
Thanks again.
12-02-2014 05:59 PM
Also the scale is just a linear 1 to 1 scale currently.
12-03-2014 04:24 PM
Im not sure if you meant to attach the same picture twice, but could you attach screenshot of the Task running in MAX and the data that you receive when the task is running?
