07-13-2005 05:13 PM
07-14-2005 08:48 AM
07-15-2005 12:12 PM
Hi all-
Dennis is correct- the example you're referring to is a Traditional NI-DAQ example that will not be compatible with your M Series card which is supported only by NI-DAQmx. In order to illustrate a finite analog acquisition in NI-DAQmx you should check out the "Acq&GraphVoltage_IntClk.vi" in the NI Example Finder by selecting Help>>Find Examples and browsing to Hardware Input and Output>>DAQmx>>Analog Measurements>>Voltage.
Thanks-
07-16-2005 02:29 PM
Greetings.
Would just the front end acquisition be incompatible? Meaning are there portions of the routine that I could use and say add a front end compatible with DAQmx?
thanks
07-18-2005 08:46 AM
07-18-2005 11:23 AM
