jo0743a,
It sounds like you need to read data more often. If this is not
possible, you need to read more data whenever you do read. Are you
programming in LabVIEW or a text-based language? In LabVIEW, you can
put the acquisitions in separate while loops and they will be able to
run at different rates. In a text-base language, you would need to look
into multithreading to independently control your read loop rates.
Hope this helps,
Ryan V.
Ryan Verret
Product Marketing Engineer
Signal Generators
