Multifunction DAQ
Cannot Simulate Devices in MAX
Hi All,
Currently trying to simulate the PCI-6503 using MAX, and when I expand the "Devices and Interfaces" tree, I see no options to create any simulated device. Software I have installed is:
1) DAQmx 9.9
2) MAX 5.6
3) Labview 2012 Evaluation Version - I used to have the full version, but my license just expired so now it is in evaluation mode.
4) NI VISA 5.2
I have been able to simulate devices in the past no problem, and haven't changed anything software wise on my computer until upgrading DAQmx yesterday to see if that's what was causing the problem (apparently it wasn't Smiley Sad ) Anything I'm missing here?
Thanks in advance!
Message 1 of 8
(5,513 Views)
can you right click and hit "create" and then create a simulated device using the dialog that appears?
Message 2 of 8
(5,512 Views)
No, these are the only options that show up (please see attached image).
Message 3 of 8
(5,509 Views)
Seems like a silily question, but did you reboot after installing? Can you expand the Software section in MAX and see what DAQmx version is there?
Message 4 of 8
(5,505 Views)
Yup, I rebooted. DAQmx version that's listed is 9.9.0
Message 5 of 8
(5,503 Views)
Accepted by topic author jenayd
Let's try...Under Tools try to reset your DAQmx data.
Message 6 of 8
(5,492 Views)
Worked like a charm! Thank you!!
Message 7 of 8
(5,485 Views)
In my new windows 10 computer, I was not able to simulate DAQ device even after resetting the configuration data.
Please find the attached screen shot with PC details and NI MAX.
Any help is appreciated!
Nandakumar
Nanda
Message 8 of 8
(2,521 Views)
