05-30-2014 04:20 PM
Hi All,
Currently trying to simulate the PCI-6503 using MAX, and when I expand the "Devices and Interfaces" tree, I see no options to create any simulated device. Software I have installed is:
1) DAQmx 9.9
2) MAX 5.6
3) Labview 2012 Evaluation Version - I used to have the full version, but my license just expired so now it is in evaluation mode.
4) NI VISA 5.2
I have been able to simulate devices in the past no problem, and haven't changed anything software wise on my computer until upgrading DAQmx yesterday to see if that's what was causing the problem (apparently it wasn't ) Anything I'm missing here?
Thanks in advance!
05-30-2014 04:24 PM
can you right click and hit "create" and then create a simulated device using the dialog that appears?
05-30-2014 04:36 PM
No, these are the only options that show up (please see attached image).
05-30-2014 04:39 PM
Seems like a silily question, but did you reboot after installing? Can you expand the Software section in MAX and see what DAQmx version is there?
05-30-2014 04:42 PM
Yup, I rebooted. DAQmx version that's listed is 9.9.0
05-30-2014 05:09 PM
Let's try...Under Tools try to reset your DAQmx data.
05-30-2014 05:29 PM
Worked like a charm! Thank you!!
01-07-2021 01:30 PM
In my new windows 10 computer, I was not able to simulate DAQ device even after resetting the configuration data.
Please find the attached screen shot with PC details and NI MAX.
Any help is appreciated!
Nandakumar
