08-08-2006 11:51 AM
08-09-2006 03:26 PM
Hello Thomas,
It is not possible to "daisy chain" multiple CompactDAQ chassis together, but you can connect multiple chassis to your computer. Then, you can export the sample clock from one chassis and import it into another if you need to synchronize the two. There are even two examples that you can look at. If you look at the examples, you will see that it is not difficult to program this application.
Laura
04-01-2015 01:16 PM
NI, the home of dead links....
04-01-2015 01:51 PM
You probably noticed that these posts were written 9 years ago...
04-03-2015 01:12 PM
If it helps, using 9469s, you can daisy chain together pretty much as many cDAQ chassis's as you want. Tasks can be configured using channels in all the chassis's you want, as long as they are set up with 9469s and properly wired.. Signals are automatically distributed by the driver.
