Multifunction DAQ
Can the DAQPAD-6016 generate a pulse train?
If so, what is the procedure and what pins are involved? Also, where can I find a 6016 Users Manual showing a pinout description?
(2,234 Views)
Avana,
Greetings!
You can find a pinout for the 6016 from this manual:
http://sine.ni.com/apps/we/nioc.vp?pc=res&cid=14041〈=US&p_0=manual
AND
Yes, you can setup a pulse train. You would use the counters. If you are using LabVIEW you can go to Help >> Find Examples to help you set this up.
Hope this helps,
AnujD
(2,234 Views)
