03-09-2016 04:49 PM
I understand from documents posted on the NI website that I cannot use the old DAQPad-6015 for USB on my new Windows 7 64-bit laptops (Lenovo ThinkPad T450), but it there a way around this? Can I use these laptops in virtual XP mode, using something like Oracle VM Virtualbox? Thank you, in advance.
03-10-2016 11:33 AM
Hi sncurrie,
Thanks for posting on the forums! Just so you are aware, this is a legacy product, which means NI no longer formally supports it and there are limited resources regarding the product. If you are starting a new project, I would recommend upgrading to a newer piece of hardware. NI recommends using USB X Series hardware for more channels and higher sampling rates now.
That being said, since the user manual indicates that you cannot use this device on your Windows 7 computer, that means that it is not supported for use on your Windows 7 machine. This means it is not supported on your Windows 7 VM, either. However, just because a product isn't supported, doesn't mean it won't work. It just means that we can't guarantee that it will work.
03-10-2016 11:39 AM
Thank you for the quick reply.
Until I can get new DAQ hardware, I will try the approach of running these Win 7, 64-bit laptops in virtual XP, 32-bit mode and see if that works as a short-term solution.
03-07-2018 08:34 PM
Excuse me. Did you succeed to use DAQPad-6015 in virtual XP, 32-bit mode or in Oracle VM Virtualbox on Windows 7, 64-bit?
