11-26-2012 02:53 PM
I'm using a cDAQ-9178 with an ADC module and a Digital IO module to develop on. Is there any way to easily port the program for use with a usb6008?
11-27-2012 10:11 AM
If you were only using the NI-DAQmx drivers on the cDAQ-9178, then the only thing you need to change is the NI-DAQmx task, change it to reference the NI USB-6008 channels instead. This is assuming that the signals your measuring/creating are also within the USB-6008 specifications.
Nathan
11-27-2012 01:14 PM
Thanks. That was easy
