Multifunction DAQ
Reply
Can I install Labview 2016 on an SD card?
can I install Labview on a SD card? I have a cDAQ-9132 with 15GB internal memory and Windows Embedded. Labview 2016 and Windows Embedded use 15GB memory. Sometime the system crashes.
Any suggestions?
Greetings from Germany
Johannes
(225 Views)
Re: Can I install Labview 2016 on an SD card?
Hello joro_kl,
you can try this, changing the Installation folder and install software to a network or usb storage should work.
best regards
Alexander Glasner
CER AES
(189 Views)
