Multifunction DAQ
Can Agilent VEE 6 Pro be used to interface to the NI-DAQmx drivers?
I have previously used VEE 6 Pro and the NI_DAQ "Traditional" interface, (Version 6.9.2) using the DLLS functions to communicate to the cards.
I now want to add one of the M series DAQ cards to an existing setup for a new test program. It appears that M-series is only to be supported by DAQmx.
Is it possible to use VEE 6 together with DAQmx?
If so, will the old programs still function if I upgrade to NI-DAQ 7.3. and develop the new program using the NI-DAQmx interface?
Can "traditional" DAQ be used simultaneously with the mx driver?
(2,638 Views)
Greetings,
You would need to contact Agilent to see if they have build DAQmx support for the VEE 6 Pro. As you mentioned, VEE 6 Pro makes DLL calls to the NI DAQ driver.
You are correct in that the M-Series boards are only supported in DAQmx. It is possible to use Traditional DAQ and DAQmx at the same time as long as you are using them on two different boards.
Hope this helps,
Anuj D.
(2,638 Views)
