I have an NI document from an NI class, entitled "Data Acquisition and Signal Conditioning Course Manual". This document indicates that if you use Channel Names, the Device Number input is ignored by AI Config (since device number information is embedded within the Virtual Channel assignment). So I thought the AI Config VI would be smart enough to recognize a list of Virtual Channels that refer to more than one device and configure the multiple devices to which the channel list refers. Alas, I ran a few tests and AI Config will successfully ignore Device Number only if all channels in the Virtual Channel list reside on the same physical device. If the channels span more than one device, AI Config bombs out (as noted). It would have been awfully handy, since it would've allowed me to set all analog inputs in my multiple-DAQ-board system, regardless of device number, to a desired configuration. Unfortunately, DAQ-MX is not an imminent option since my company needs to maintain and improve legacy hardware that is permanently installed at remote customer sites.
Thank you for your input!
