09-23-2016 09:31 AM
I need to use the C# NET API from a java program, so I have been trying to use Jni4net library to bridge the dll over to Java. I'm getting errors however, because the version of daqmx.dll that I have was built against CLR 2.0.50727. Is there a version of the dll for CLR 4.0 (Corresponding to .NET 4.0 or greater)?
Alternatively does anybody know another way of calling daqmx.dll from java?
09-26-2016 04:53 PM
Do you have the DAQmx.dll assembly or the C dll? If you have the .NET assembly, where did you get it from?
Best Regards,
09-30-2016 08:51 AM
I ended up getting the version I had to work.
I have the DAQmx.dll assembly. I got it from an old software project developed for the device I'm working on. I assume the original developer got it from the driver disk from National Instruments.
