Multifunction DAQ
Building a multi-daq acquisition system to track 32 analog channels
So I got around the data logging problem by adding in a write vi log before the while loop and it records everything perfectly. Except there is no timestamp for the data points. How can i add this in? Ideally in real time similar to the timestamp in the write measurement file vi.
Message 11 of 12
(1,386 Views)
Because you are only taking one sample for each of the iterations of the main while loop, you could add a current timestamp to the data added to the queue. This could be written to file along with the samples and provide a reasonably accurate timestamp for each iteration of the loop.
Message 12 of 12
(1,370 Views)
