HI,
I have a PXI-6071E, and I intend to use all 64 analog i/p channels in it. I will be connecting the sensor signal to all the 64 channels on my device.
I want the use labview program wherein the user selects which signals he is interested in viewing, and only the channels corresponding to the user choice should be displayed in the labview window(only interested channels need to be sampled, other channels need not be).
My questions are;
1. Can I have names given to channels ..like analoginput 0 as 'Voltage field sensor' while creating a task? I have not used NI DAQmx before...is there any links about how to configure tasks and use them?
2. Can I have different sampling rates for different analog ip channels, when I am
reading more than one analog input in my application?
Thank you.
