05-11-2017 12:42 AM
I tried the tricks listed for LV 8.5, but they don't work with 8.2...
- If there is no way to run with LV 8.2, is 8.5 the lowest version that will operate the cDAQ-9171? (using the 9.3/9.5 partial install trick...?)
- Assuming that is the case, is there an inexpensive way to upgrade 8.2 to 8.5?
I am a hobbyist and can't afford the latest and greatest; what are some of my upgrade options?
Jim
05-11-2017 10:08 AM
Unfortunately, I don't think so. The latest driver supported by 8.2 still does not support the 9171. Upgrading from 8.2 to 8.5 will not be possible because 8.5 cannot even be purchased any longer.
If all you need is personal access to the software, you may be interested in this one.
http://sine.ni.com/nips/cds/view/p/lang/en/nid/213095
http://store.digilentinc.com/labview-home-bundle/
Hope it helps.
05-11-2017 11:06 AM
Thanks, Camilo, that is EXACTLY what I need...
