I'm trying to sample from two analog input channels simultaneously. Both channels use the differential reference method. Channel 4 monitors a function generator outputing a wave at 40kHz between 10 and -10 volts. Channel 7 monitors a transducer outputing at 40kHz between 50 and -50 mV. For some reason, even if the transducer is not connected, I get +/- 1.25 V on channel 7 when the FG is running. Is this just a ridiculous amount of noise or did I not hook something up right? Also, when I graph these waveforms in LV, they looked squished (like a big solid block instead of a wave) even though I sample them at 200kHz. Any help with that would be appreciated also. Thanks guys.
Darren
