Multifunction DAQ
All the Traditional NI-DAQVirtual Channels not displayed
I am using Labview version 7 and I have a trouble in viewing all the channels in Measurement and Automation.
I have 15 channels and I am using 9 of them and I cannot see all the channels names listed as:
Configuration
My System
Data Neighborhood
Traditional NI-DAQ Virtual Channels
Channel 1
Channel 2
Channel 3
Channel 4
I am new to Labview and trying to learn. Please help me by giving a solution to my query. How can I see all the 9 channels in Data Neighborhood?
Thanks in Advance.
(2,484 Views)
Hello Tricity,
I can definitely help you out! I want to understand better the problem you are having though. Please answer these questions so that we can work on this better:
1. What board do you have?
2. What type of channels do you want to create (AI/AO/DIO/CTR)?
2. Are you able to create the 9 virtual channels that you want in MAX? (If you can create them, you should be able to see them listed under the folder Traditional NI-DAQ Virtual Channels folder. If you can create only a limited number of channels, this probably means that you have that many channels to work with.)
the more information you can give me about your problem the better I would be able to help you out. If you can send me screenshots of your problem that can help as well.
LA
(2,469 Views)
Thanks a lot LA for your reply. I figured it out and am working on it, if I am unable to get it, would get back to you.
Thanks once again
Tc
(2,457 Views)
