Hello-
Can you please let us know a bit more about how you're configuring your tasks and connecting the signals?
Are you using a differential connection or grounding one of the pins (i.e. RSE as suggested by TipTop)?
Also, are you creating the tasks/channels programmatically or in MAX? Also, do you see the same behavior in Test Panels in MAX?
Any insight into the connections and how you're measuring them would be helpful in troubleshooting the problem.
Tom W
