Multifunction DAQ
ANSI C Create Task vs. Reconfiguring
Greeting fellow data acquirerers,
I have a question regarding the NI DAQmx C API. I have a very basic application in Qt (for GUI) to start, stop, reconfigure and plot a measurement with a USB-6255 DAQ. The program is built up as follows:
  • At the start of the program I create a task
  • The task is configured with some initial parameters
  • Upon button press this task can be started and stopped
  • There are button for changing the sample rate, samples per channel and dynamic range
  • Upon changing a value in any of the aforementioned controls the task is stopped, the parameters reconfigured and started again
The initial initialization consists of:
  • DAQmxCreateAIVoltageChan to add the required channels to the task
  • DAQmxCfgSampClkTiming to configure the sample clock
  • DAQmxSetBufInputBufSize to 10 times the samples per channel value
  • DAQmxRegisterEveryNSamplesEvent to configure the callback
The problem seems to be, when I choose certain parameters (for example 10000 Hz rate and 10000 samples per channel) DAQmx issues an error that my application can't keep up with the acquisition. I reconfigure the task in the following way:
  • If the task was running, stop it
  • Call DAQmxCfgSamlClkTiming with the new parameters
  • Call DAQmxSetAIMax/Min with the new parameters
  • Call DAQmxSetBufInputBufSize to set the buffer to 10 times the new samples per channel value
  • Unregister my EveryNSamplesEvent
  • Register an EveryNSamplesEvent with the new parameters
  • Restart the task, if it was running before
Now comes the twist. If, instead of stopping, reconfiguring and restarting the task, I clear the task and just perform the initial configuration with the new parameters everything works well. So my question in short would be: What happens between deleting, recreating and configuring the task that calling the configuration functions repeatedly does not do? In my opinion I am performing the same configuration steps (obviously without the channel creation) in the initialization and in the reconfiguration, so it seems odd to me that I get different results.
I would be happy about any suggestions. Thanks in advance,
FB.
(4,005 Views)
You posted to the LabVIEW board. Repost or click on Options and ask the moderator to move it.
(3,974 Views)
