12-14-2016 10:48 AM
We have a NI DAQ card PCI-5153.
http://sine.ni.com/nips/cds/view/p/lang/en/nid/205618
We are trying to connect it to the motherboard of our computer Dell-Precision-T1700 SFF. But we are not sure if the slot is compatible. Should this DAQ card work in this motherboard? If not, is there any adaptors or cables that we can buy?
Thank you!
Shanshan Tang
12-14-2016 12:36 PM
Look at the chassis section of the data sheet you linked. The SFF only has PCIe slots and the card IS PCI. You can look up PCIe to PCI adapters on Google and you will find some, but I have never used one. I would suggest getting a computer with a PCI slot.
Are you even sure that card will fit into your computer? It looks quite large for a SFF computer.
12-15-2016 04:34 PM
Thank you so much! And it is a problem that the case is too small. We are looking for a new big case.
