09-13-2006 02:14 PM
09-14-2006 12:25 PM
03-20-2012 12:36 AM
Hi Neil ,
My application requires a differential square wave . What is the best solution to this ? (There are more than 40 Analog Inputs Required and a differrential Square wave Output from the Daq Unit .Suggest an optimum Solution.)
03-21-2012 10:42 AM
Hi kansal,
Do you have a form factor preference? PCI/PXI/USB? What is the amplitude and frequency of the required square wave? What is the amplitude and frequency of your analog inputs? How much resolution do you need?
I'll be happy to help you find a solution to meet your system requirements. If you would like to explore some of the options on your own make sure to visit our website at ni.com/products. You can search for hardware and filter by your specifications to find a configuration that will best meet your needs.
Best Regards
Andrew S.
01-04-2017 02:39 PM
Is there a USB device that can output a differential pulse? Can this be done with two analog outputs and a virtual channel?
01-05-2017 11:30 AM
Hi Justin,
I noticed that you opened a service request with this same question - let's communicate through that to prevent repeat messages. Thanks!
Best,
Angela Li
