Motion Control and Motor Drives
the IP address of Starter kit2 robot changed
I use the Hardware setup wizard to configure the Starter Kit2 Robot. At step3, the robot was detected successfully, but the IP adress was 0.0.0.0 which was different from the correct address:169.254.0.1. so I can not go through the following steps. I tried several methods to solve this problem, reset the robot, restart the host PC and reconnect the ethernet cable, but failed.
By the way, Is there any other method to launch the Hardware setup Wizard except restart the LabView program? Every time after I deployed the program on the robot and disconnect the ethernet cable to test my program, if I want to revise my program, I need to close all programs and restart labview in order to launch the he Hardware setup Wizard. It's not convenient!
Thanks!
Message 1 of 1
(2,939 Views)
