I'm using NI motion assistant to create 2 different motions in 2 vi's. Each motion includes a lot of different positions with measurements in between.
I have put these 2 motions vi's in a state machine.
The problem I have is that I need to stop each motion while they are executing before they end (cancel the motion). The best would be to be able to switch between the 2 motions using a single control, or two. Any idea how I need to implement that? If possible, please draft an example code.
Thanks a lot
