01-05-2014 11:54 PM
how to run 2 tdc001 controller at the same time,below is my design and i cant run and get reading at the same time.The another motor run after the first motor run.
01-09-2014 03:58 AM
Good day to you. Have you tried looking at the flow of the code (using highlight execution)? Can you check if data flow for both lines of code is simultaneous?
I found another link which explains how to cope with calling multpile and parallel activeX instances. It is related to increasing the number of threads LabVIEW allocates per execution system.
http://forums.ni.com/t5/LabVIEW/Calling-Multiple-and-parallel-ActiveX-instances/td-p/704543
Alan
