04-13-2012 01:10 PM
I'm wondering if there is a way to read the index signal from my encoder (aside from using the find reference VI's) without having to split the wire into a digital I/O pin. I'm trying to use a position feedback potentiometer and index signal from a motor to do a find home routine.
Thomas from GTPUMA
04-17-2012 09:21 AM
Thomas,
It depends on the encoder and other hardware you are using. On the encoders I have worked with, the index signal was a digital signal and thus would require a digital I/O pin. I would say that your find reference VIs are going to be the best way to go, is there something in your application which prevents you from using them?
Greg H.
04-17-2012 02:21 PM
My home position is specified by an analog value (potentiometer) hence, I can't use the Find Reference VI's.
04-18-2012 02:41 PM
What particular device are you using?
I think I am confused as to what you are trying to do then. If you are using an analog potentiometer then you should be able to find the home position based on that, you wouldn't need to use the index signal. You also cannot use both as feedback. If you just use the potentiometer then you know what voltage level corresponds to the home position and this is all you need.
Greg H.
My Profile | Privacy |
Legal |
Contact NI
© 2011 National Instruments Corporation. All rights reserved. | E-Mail this Page
E-Mail this Page
