05-19-2015 06:52 AM
Hi there,
I am currently wanting to control the motion of the motorised mount using Labview, but I dont have examples, Can you ,possibly, help me please?
The mount Model is: Newport rotation stage Model URS50BBC.
Thank you ,
Maab
05-22-2015 05:50 AM
I downloeded the driver and examples for it from this websit:
http://www.newport.com/URS-Series-Precision-Rotation-Stages/303761/1033/info.aspx#tab_Literature
But they didnt work, there are some question marks appeared in the block diagram!
Can anyone know about that?
Any advise is appreciated
05-28-2015 03:48 AM
Hi Misk,
The question marks which appear on the block diagram indicate that you don't have the relative functions in your LabVIEW package. Depending upon the functions, the relevant toolkits can be downloaded and installed.
05-29-2015 06:54 AM
Hi CasiL,
Thank you for this.
I doenloaded them, and it is Ok now, however , the example need COM adress ,when I put 1 , it says : failed in connection and somthing about VISA identification..
I dont know how can I found VISA or code library,I will attach the error box.
Thank you very much,
Maab
05-29-2015 10:37 PM
06-01-2015 08:14 AM
Hi there,
Thank you Dennis Knutson for that , I downloaded tha VISA from the website, however it still doesnt work ..
When I run the virtual control pannel vi , it doesnt connect and apears: NOT referenced from reset as see in the attached picture.
Can anyonr helps me please?
Maab
06-01-2015 11:33 AM
06-02-2015 04:09 AM
Yes, I asked them ..they said that I have to home the stage before the cotroller , as I am new to labview , I dont know how to home the stage..
Can you see the attached picture , the problem in this sub vi , I think..
Any advice is appreciated ,
Many thanks
06-02-2015 04:10 AM
Sorry , her the picture..
Regards
06-02-2015 12:01 PM
Hi there ,
I solved it , it somthing related to NI MAX .
However , can someone advise me how to control this Newport motor stage with COHERENT power meter , I can control them by labview but seperately , but how can I run them in the sametime by labview?
Any advice and suggession are appreciated ,
Many thanks,
Maab
