09-07-2015 05:14 AM
09-08-2015 10:19 AM
Hi Tati89,
What's the problem you're experiencing? What is the controller you're using? Are you using EtherCAT?
Also, here are a few resources in case you have not seen them. Also I would recommend looking at some of the examples in the NI Example Finder.
http://www.ni.com/pdf/manuals/AKD_Install.pdf
http://www.ni.com/pdf/manuals/375592b.pdf
http://www.ni.com/pdf/manuals/375543c.pdf
I hope this helps!
- Kale
12-09-2016 09:44 AM
I want to make sure that I share the latest revision of the Getting Started with AKD EtherCAT® Drives and the LabVIEW NI SoftMotion Module document.
