NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
sivan2005
epos 2
I am using LabVIEW to control EPOS2. I have the library functions. This program is working with my PC. Which means i can control all the EPOS2 in my PC.
However, when i transfer all my files into a laptop, the EPOS2 could not be controlled in LabVIEW through laptop.
It gives "error reading USB data. (0x23000002)"
Please advise..
Attached is the file and library
Member
Doiron
Re: epos 2
How are you connecting to the EPOS2?
With warm regards,
David D.
Member
pmlnme
Re: epos 2
Thanks for Sharing
Member
sivan2005
Re: epos 2
The issue have been solved with the new EPOS library function with the RED color initialize icon
Member
xiaohai0124
回复: epos 2
I want to know how to connect the maxon motor's drive to the cRio?
Active Participant
Nate.H
回复: epos 2
Find the download and information on using it here:
http://sine.ni.com/nips/cds/view/p/lang/en/nid/209755
Best Regards,
Nate
Member
xiaohai0124
回复: epos 2
THXs,I will try to do so
Member
xiaohai0124
回复: epos 2
Do you use the laptop with the wireless?
Member
AlirezaMPB
Re: epos 2
I hope that you already solved the problem of "Reading USB data" from the epos2. If yes, would you please let me know how to solve this problem as I am receiving the same Error from the EPOS.
For your information, I am using linux (ubuntu) and the libEposCmd library from maxon.
Cheers
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
