06-17-2011 01:24 AM
I am using LabVIEW to control EPOS2. I have the library functions. This program is working with my PC. Which means i can control all the EPOS2 in my PC.
However, when i transfer all my files into a laptop, the EPOS2 could not be controlled in LabVIEW through laptop.
It gives "error reading USB data. (0x23000002)"
Please advise..
Attached is the file and library
08-05-2011 01:50 PM
How are you connecting to the EPOS2?
08-06-2011 01:48 AM
Thanks for Sharing
08-12-2011 10:42 AM
The issue have been solved with the new EPOS library function with the RED color initialize icon
08-26-2011 03:24 AM
I want to know how to connect the maxon motor's drive to the cRio?
08-26-2011 09:10 AM
Find the download and information on using it here:
http://sine.ni.com/nips/cds/view/p/lang/en/nid/209755
Best Regards,
Nate
08-27-2011 08:30 AM
THXs,I will try to do so
08-29-2011 03:41 AM
Do you use the laptop with the wireless?
02-21-2012 09:40 AM
I hope that you already solved the problem of "Reading USB data" from the epos2. If yes, would you please let me know how to solve this problem as I am receiving the same Error from the EPOS.
For your information, I am using linux (ubuntu) and the libEposCmd library from maxon.
Cheers
