We want to write a motion control aplication using the VS Express C++ with a .dnet framework 2.0. We would like to use the existing C examples provided as guideline to build out application. Currently I have the following problems:
1. The NIMCexample.c file does not compile in debug mode. We have a buffer overun as well. I suspect this due tot he fact that the C code wants to use malloc to manage memory and C++ is using another memory manager.
Can any body suggest what we can do to overcome this problem?
I also heard that using c# is probably a better alternative to C++ when working with c code.
Thanx in advance.
Regards
Thivash
