02-27-2012 11:22 PM
i have single-end encoder .how can do it ? change from single-end to be differential output .
thank you
02-28-2012 04:38 AM
You have to add some circuitry. The IC AM26LS31 has TTL compatible inputs and RS485 compatible differential outputs which will be compatible with the UMI box.
Using differential signals is recommended when you have long signal lines, the differential signal transmission is much less sensitive to environment noise. You should use twisted pair cables if possible. Of course the TTL-to-differential-signal-converter should be located as close as possible to the encoder.
02-29-2012 09:05 PM
Did i make it correct?
Do i have to connect resistor pull up ?
When I have to connect pull up resistor ?
03-01-2012 12:52 AM
1. You have to connect the /G input to GND.
2. You mention the A channel only. The NI boards will accept signals from incremental encoders only, so there should be a B channel output on your encoder as well?? You can use the second half of the AM26LS31 to convert the B output signals.
03-01-2012 02:43 AM
please explain principles of brush servo control . How to control voltage at analog output(DAC CHANNEL) when i choose servo external commutation on axis configuration on MAX.
03-02-2012 07:03 AM
oops ... should read "one more converter circuit contained in the AM26LS31" instead of "the second half". The AM26LS31 contains four converter circuits for TTL to RS485 signal conversion.
There is no need for connecting unused inputs via pull-up resistors to +5VDC or directly to GND, the AM26LS31 has pull-up resistors on all inputs.
03-06-2012 03:51 AM
thank you very much
