Motion Control and Motor Drives
VI's using Boolean with "Latch Until Released" or "Switch Until Released" Mechanical Action cannot be downloaded
Hi Folks,
I'm using LabView 2014 Pro, Softmotion and a Real Time module with a CRIO 9068 chassis and 9512 stepper controllers. I'm trying to create a momentary button to jog my steppers and I get the error posted above. I searched the forums and found a similar post where it stated a switch set for Latch Until Released or Switch Until Released is not allowed by the RT module. Obviously this is still the case, but I was wondering if someone had an alternate method for performing the same function.
David
(5,113 Views)
Hi David,
If you right-click on the boolean and go to Mechanical Action, are you able to get this to work if you chance the action to one of the other four actions?
Rahul B.
(5,087 Views)
Hi Rahul,
Unfortunately not. It appears that I have communicate with the RT VI via the remote VI utilizing shared variables. I spoke with an App Engineer earlier and he recommended this route. I'm in the process of testing this now.
Thank you very much for the response though.
David
(5,081 Views)
