01-29-2015 07:40 AM
Hi Folks,
I'm using LabView 2014 Pro, Softmotion and a Real Time module with a CRIO 9068 chassis and 9512 stepper controllers. I'm trying to create a momentary button to jog my steppers and I get the error posted above. I searched the forums and found a similar post where it stated a switch set for Latch Until Released or Switch Until Released is not allowed by the RT module. Obviously this is still the case, but I was wondering if someone had an alternate method for performing the same function.
David
01-30-2015 01:53 PM
Hi David,
If you right-click on the boolean and go to Mechanical Action, are you able to get this to work if you chance the action to one of the other four actions?
01-30-2015 03:35 PM
Hi Rahul,
Unfortunately not. It appears that I have communicate with the RT VI via the remote VI utilizing shared variables. I spoke with an App Engineer earlier and he recommended this route. I'm in the process of testing this now.
Thank you very much for the response though.
David
