02-23-2006 09:31 AM
02-24-2006 06:02 PM
02-27-2006 08:56 AM
I am familiar with the UMI-7774 manual. We have been using it all along to try to troubleshoot this issue.
We are measuring voltage between pin 6 and Ciso, but the problem remains, that even thought I can successfully toggle the LEDs for each axis, I am not seeing any voltage difference between pin 6 and Ciso.
02-27-2006 10:56 PM
Hi GregH,
The best way to solve this problem is to first find out, whether the card is faulty or the umi is faulty. The method is as follows.
Take a blank PCB and connect 68 connectors to it. Get a 68 pin connector crimped to a 68 core cable at one end that fits into the PC. The other end of the cable has loose wires. Now assign ferul numbers to each cable from 1 to 68 and connect each of these to the connectors in the PCB. Now check the voltage levels at which ever pins you want. If you see a voltage, then you can replace your UMI and if you dont, then you can replace your card. I've tried this when my ADC on the motion controller was not working and found that the card was faulty. Be careful before trying it. I tried this under the guidance of a motion control expert. If you are not sure then you can send it to NI for checking or contact a field engineer in your location.
Giridhar Rajan
Automation Engineer, Design
Cruiser Controls
Mumbai, India
12-20-2008 08:45 AM
GregH - do you have solution for this? i have SAME problem and trying to solve it for long time,
please reply if you can, i really appriciate your solution here.
any help is most welcome here
MotiM
02-17-2017 04:07 AM
If you have Viso = 24v then you will get output voltage for Enable axis of 24V logic,
For low it will be min. 0v to maximum 2.0v
For high it will be min. 2.5v to maximum Viso.
Your drive may be TTL (0-5v) logic level, if it is so, connect 5v supply at Viso instead of 24v.
