08-04-2014 09:21 PM
Is it possible to use the Motion Assistant when I write a program on the platform of labview version 13.0.0 (64-bit), with an operating system of Win7? If so, then how?
Any necessary information will be appreciated!
08-05-2014 07:37 PM
Yes.
You can just download Motion Assistant and install it,and use it in Labview.
08-05-2014 08:35 PM
Firstly, thank you for your recommendation. But, unfortunately, when I installed and set up the Motion Assistant, I was offered options only for Labview 32-bit, no for 64-bit.
Any furthermore suggestion?
08-11-2014 12:41 AM
Hi
08-13-2014 09:54 AM
Thanks very much. But unfortunately, another application communicating with LV make 64-bit LV necessary.
08-13-2014 10:27 AM
Does the other application specifically require 64-bit LabVIEW, or does it just need to run on a 64-bit OS? The 32-bit version of LabVIEW can run on a 64-bit OS; In fact, this is probably one of the most common ways LabVIEW is used.
