11-21-2009 11:52 AM
11-21-2009 11:54 AM
11-21-2009 11:57 AM
11-23-2009 10:37 AM
05-14-2014 06:27 PM - edited 05-14-2014 06:28 PM
Hi MatL,
I am having the same issue you did with error code -2147352567. I am using ActiveX communication to control MATLAB via LabVIEW. Can you explain in detail what you did to solve this issue?
05-16-2014 10:56 AM
Huzzah. I finally have justification for keeping all those uni notes.
I can't fully explain it here, its been some years and I don't have a copy of Labview to poke around with. So I'm sorry if this is not 100% correct.
Essentially I was getting the error because I was passing the ActiveX components bad inputs and they in turn were spitting back error messages which were not being correctly interpreted by LabView. This confused me as the error code was not in the documentation for LabView or the Baldor software I was using.
I managed to work around by trial-and-error to find out what inputs worked.
I stumbled accross the solution by chance (about two weeks before the project was due and after finishing most of the work, such is life) there is an ActiveX error handling function somewhere, if linked to the error output of the ActiveX command function it would give you a useful answer.
Hope I'm not too late to help, feels a bit like http://xkcd.com/979/
