NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Active Participant
ceties
Re: USS protocol library
It shouldn't matter. You just have to set the inverter accordingly
LV 2011, Win7
Member
michael87
hi flo!!!
help please!!!
how I can change P2012 and P2013 in mm440 or you uss library??? becouse I have error 5008(incorrect byte count) if baud rate 9600 or error 5007(missing STX) if baud rate 38400
Member
Gilberto Garza
Is there a way to have these libraries in 8.5 LabView version please?
I am developing a project with some 420 and 440 drives, and it would be great to use this library.
Gilberto Garza
Gilberto Garza Gzz.
Certified LabView Developer
Asesor Electrico, S.A. de C.V.
Active Participant
Zenon K.
Dear Gilberto,
I have conerted the files Flo has posted to LabVIEW 8.5 format, I hope it will work for you. If it doesn't or if you have any other questions, please don't hesitate to ask.
Have a wonderful day!
Zenon Kuder
Applications Engineering
Member
Gilberto Garza
Thank you very much Zenon, it will help me a lot!
Gilberto Garza
Gilberto Garza Gzz.
Member
Parga
Do you have the files available for LabVIEW 8.2?
Active Participant
Zenon K.
Dear Parga,
I converted the files for LabVIEW 8.2, nevertheless there were some changes in several of the used VIs, so I'm not sure if it will work for you. Can you please check and let me know if it did work or not?
Thanks you!
Zenon Kuder
Member
Parga
Dear Zenon,
Let me play with the files and my inverter for a couple of days and then I will let you know if I have troubles with them.
Thank you very much for your promptly support.
Abraham Parga
Member
Gilberto Garza
Thank you very much, I am working with the MM420 now and the PZD is max of 4 words, do I have to modify the vi PZD_USS.vi to make it work?
Gilberto Garza
Gilberto Garza Gzz.
Active Participant
ceties
The original library expects PZD=8. So you will have to dive into the code to alter it. Not sure about the altered llb intended for MM440 but if it now reads also 8 words, it will be same case.
LV 2011, Win7
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
